OneDriveConnector
Accesses the Microsoft OneDrive file storage service to upload, download, or delete files and folders or list the contents of a folder from a Microsoft OneDrive account.
- Manage datasets on Microsoft OneDrive by uploading, downloading, and deleting files and folders
- Transfer a file's contents (such as XML or raster) into or out of an attribute in FME
- Read downloaded Microsoft OneDrive data using the FeatureReader, or upload data written by the FeatureWriter to Microsoft OneDrive
- Retrieve file and folder names, paths, links and other information from Microsoft OneDrive to use elsewhere in a workspace.
The OneDriveConnector uses your Microsoft OneDrive account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service. This connector is compatible with OneDrive personal and OneDrive for Business accounts.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On uploads, link attributes are added to the output features. On List actions, links and file/folder information are added as attributes.
In this example, the OneDriveConnector is used to download an Esri Geodatabase from Microsoft OneDrive. After creating a valid web connection to a Microsoft OneDrive account (which can be done right in the Microsoft OneDrive Account parameter), and browsing to the geodatabase folder, the Object ID is retrieved, and a destination for the download is selected.
A FeatureReader is added to read the newly downloaded dataset. Here, the PostalAddress feature type will be further processed elsewhere in the workspace.
By executing the download here in the workspace, the geodatabase will be refreshed every time the workspace is run.
In this example portion of a workspace, the OneDriveConnector is used to download a raster orthoimage from Microsoft OneDrive into an attribute.
The file is read from Microsoft OneDrive, and the contents stored as a blob attribute. Then a RasterReplacer is used to interpret the blob into a usable raster format.
The combination of these two transformers avoids having to download the image to local storage and re-read it. A similar technique can be used for point cloud files, using the PointCloudReplacer transformer.
- This transformer cannot be used to directly move or copy files between different Microsoft OneDrive locations. However, multiple OneDriveConnectors can be used to accomplish these tasks.
- The FeatureReader can access Microsoft OneDrive directly (without using the OneDriveConnector), however, a local copy of the dataset will not be created.
The output of this transformer will vary depending on the Microsoft OneDrive Action performed.
- After an Upload action, URLs to the file may be saved to the Sharable Link and Direct Download Link attributes, and the ID of the file will be saved to an attribute.
- A Download action can save to a file, a folder, or an attribute.
- A Delete action has no output ports.
- A List action will output a new feature for each file/folder found in the path specified. Each of these new features will have attributes listing various pieces of information about the object.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the OneDriveConnector already having a value for fme_rejection_code, this value will be removed.
Microsoft OneDrive Action |
The type of operation to perform. Choices include:
Microsoft OneDrive Account |
Performing operations against a Microsoft OneDrive account requires the use of OAuth2 authentication using a Web Connection. To create a Microsoft OneDrive connection, click the 'Microsoft OneDrive Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. Note that the ‘Microsoft OneDrive (Graph)’ service should be used, as the ‘Microsoft OneDrive’ service is not compatible with OneDrive for Business. |
The remaining parameters available depend on the value of the Microsoft OneDrive Action parameter. Parameters for each Microsoft OneDrive Action are detailed below.
Microsoft OneDrive Path
Object ID |
The Object ID of a file or folder on Microsoft OneDrive to delete. If valid credentials have been provided as a web connection, you may browse to a location. |
Microsoft OneDrive Source
Object ID |
The Microsoft OneDrive ID of the file/folder to download. If valid credentials have been provided as a web connection, you may browse to a location. |
Destination
Download as |
Select whether to store the downloaded data in a File, Folder or Attribute.
Download to Folder | Specify the path to the folder that will store the downloaded file. Valid for Download as File or Folder. |
Include Subfolders | Choose whether to download subfolders of the Microsoft OneDrive Source or not. Valid for Download as Folder only. |
Download to Attribute |
Specify the attribute that will store the contents of the downloaded file. Valid for Download as Attribute only. Note: FME will attempt to convert the attribute's contents to a UTF-8 string. If this fails, the attribute's contents will be created as raw binary. To ensure that the original bytes are always preserved and never converted to UTF-8, use Download as File instead. |
Folder ID |
The folder ID on Microsoft OneDrive to list the contents of. If valid credentials have been provided as a web connection, you may browse to a location. |
Output Attributes
Default attribute names are provided, and may be overwritten.
File or Folder Name |
Specify the attribute to hold the name of an object on Microsoft OneDrive. |
File or Folder ID |
Specify the attribute to hold the ID of an object on Microsoft OneDrive. |
File or Folder Link |
Specify the attribute to hold the link to an object on Microsoft OneDrive. |
File Size |
Specify the attribute to hold the size of a file object on Microsoft OneDrive. |
Last Modified |
Specify the attribute to hold the last modified date of an object on Microsoft OneDrive. |
File or Folder Flag |
Specify the attribute to hold the type (file or folder) of an object on Microsoft OneDrive. |
Relative Path |
Specify the attribute to hold the relative path to an object on Microsoft OneDrive. |
Source
Upload |
The type of data to be uploaded.
When working with large objects, File is a better choice than Attribute as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature. Microsoft OneDrive treats file uploads of the same name, in a specific folder, as overwrites, so if you upload files that already exist in that folder, they will be overwritten by the upload. When wanting to upload content from a folder, it is better to upload as a folder instead of setting a fixed path and sending multiple features into the connector to upload as a file. |
File to Upload |
The file to be uploaded to Microsoft OneDrive if Upload is set to File. |
Folder to Upload |
The folder to be uploaded to Microsoft OneDrive if Upload is set to Folder. |
Choose whether to upload subfolders of the Folder to Upload or not. |
Attribute to Upload as File |
The data to be uploaded, supplied from an attribute if Upload is set to Attribute. |
Microsoft OneDrive Destination
Folder ID | The path on Microsoft OneDrive to upload the source file to. To upload to the root directory, enter “/”. |
Upload with File Name | The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .txt, .jpg, .doc). |
Output Attributes
Sharable Link |
Specify the output attribute that will store a temporary publicly accessible URL that links to the file on Microsoft OneDrive. |
Direct Download Link |
Specify the output attribute that will store a URL that links to the file on Microsoft OneDrive. The URL can only be used by authenticated users. |
File or Folder Id |
Specify the output attribute that will store the ID of the file/folder that was just uploaded. |
A set of control characters is available in the Text Editor. | |
Working with User Parameters | Create your own editable parameters. |
Dependencies | Microsoft OneDrive account |
FME Licensing Level | FME Base Edition and above |
Aliases | |
History | Released FME 2017.0 |
Categories |
Search for all results about the OneDriveConnector on the FME Community.
