PointCloudReplacer
The point cloud format used to decode the blob.
The attribute from which the blob will be read.
Note that this transformer only works with point cloud formats. Use the GeometryReplacer for vector formats or the RasterReplacer for raster formats.
Currently supported formats include:
- ASPRS Lidar Data Exchange Format (LAS)
- ASPRS Lidar Data Exchange Format Compressed (LAZ)
- Cesium 3D Point Cloud (pnts)
Related Transformers
This transformer is typically used to restore a point cloud previously extracted into an attribute by the PointCloudExtractor.
Transformer Categories
FME Licensing Level
Technical History
FME Factory Used: @GeometryFormat
Search FME Community
Tags Keywords: geometry database extract replace blob serialize
