Geocoder
Uses various external web services to convert addresses to latitude/longitude coordinates, or to find the closest addresses to latitude/longitude coordinates (reverse geocode). Some services have additional information available, such as time zone or elevation.
Jump to Configuration
  • Find coordinates and create geometry for a list of street addresses
  • Find addresses that match coordinates
The Geocoder provides a single interface to numerous geocoding web services. Once a service is selected, the appropriate parameters are presented, including connection credentials and the expected attributes the service needs to perform geocoding.
As features pass through the transformer, these attributes are passed to the service, and the results retrieved.
If the feature is successfully matched by the service, the results (attributes and/or geometry) are added to the feature and it is output through the Output port.
If the feature geocoding fails for any reason (including addresses not found, invalid coordinates, or failed credential authentication), it is output through the <Rejected> port.
Modes
The Geocoder can perform a variety of tasks, dependent upon which service you choose to use. Each service will provide one or more of these modes of geocoding:
Forward Street Address Geocoding
Single free form street address to latitude/longitude values, for example:
"7445, 132nd Street, Surrey, BC, V3W 1J8"
Discrete street address elements to latitude/longitude values, for example:
"7445"
"132nd"
"Street"
"Surrey"
"BC"
"V3W 1J8"
Forward Street Address with Proximity Geocoding
Single free form street address and approximate latitude/longitude to precise latitude/longitude values
Discrete street address elements and approximate latitude/longitude to precise latitude/longitude values
Forward IP Address Geocoding
IP address string to latitude/longitude values
Reverse Street Address Geocoding
Latitude/longitude values to a single street address string
Reverse Elevation Geocoding
Latitude/longitude values to elevation in meters
Reverse Timezone Geocoding
Latitude/longitude values to timezone code, name and offset
The geocoding service result is stored in output feature attributes, feature geometry, or both. For example, latitude/longitude output is represented on the feature as a point geometry, and also as ‘_latitude’ and ‘_longitude’ attributes.
  • Many services have restrictions on how their results may be used or displayed. Check with your chosen service for terms and conditions. See available services.
  • The expected input address format varies between services. See documentation provided by your chosen service for details.
  • If you need to create address strings for your chosen service, you can build them right in the Geocoder using the Text Editor, or consider using the AttributeManager to construct them as persistent attributes.
This is a complete list of possible parameters for all services accessed by the Geocoder. Only the service-specific required parameters will be shown in the transformer once a service has been chosen.
Geocoding Services
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies External geocoding web service(s)
FME Licensing Level FME Base Edition and above
Aliases
History Released FME 2017.0
Categories
Integrations
Web
Search for all results about the Geocoder on the FME Community.
