CoordinateExtractor
Retrieves the value of the x, y, and z coordinate at the specified index into attributes.
Features with extracted coordinates stored in attributes are output through this port.
Features where the specified coordinate was out of range will be output through this port.
Mode
- The All Coordinates mode will extract all the coordinates into a list, the name of which the user may specify.
- The Specify Coordinate mode only returns one set of coordinates at an index specified in the Coordinate Index parameter. If the index is out of range, the feature will be rejected. The parameters for each mode will only be enabled if their mode is selected.
If the feature was two-dimensional, then the Z attribute will be given the default value specified.
All Coordinates
Name of the list that will contain all extracted coordinates when the All Coordinates mode is used.
Specify Coordinate
The index can be entered as an integer, or may be taken from the value of another attribute by selecting the attribute name from the pull-down list. A negative index can be used to indicate the position relative to the end of the feature (-1 is the last coordinate, -2 the second last, and so on). If the index is invalid, then the feature will be rejected.
Names of the attributes containing the x-, y-, and z-coordinate values that are retrieved.
Transformer Categories
Transformer History
This transformer was renamed from CoordinateFetcher.
Technical History
Associated FME function or factory: @Coordinate, @Dimension
Search FME Community
Tags Keywords: CoordinateFetcher
