AzureQueueStorageConnector
Accesses the Azure Queue Storage service to send or receive messages.
Jump to Configuration
- Aggregation of data from queues and other message streams
- Trigger an action from a message
The AzureQueueStorageConnector uses your Azure Storage account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the queue storage service.
- The queue storage service xml encodes and decodes messages in utf-8 by default
Input
Output
The output of this transformer will vary depending on the action performed. Message data and metadata are presented as feature attributes.
- After a Receive action, output features represent messages received from the queue.
- After a Send action, output features represent messages sent to the queue.
Initiator
The incoming feature is output through this port.
<Rejected>
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the AzureQueueStorageConnector already having a value for fme_rejection_code, this value will be removed.
Authentication
Credential Source
Required for authentication. Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
- Web Connection - use an Azure Storage web connection stored in the FME web connections database
- SAS - use a Shared Account Signature instead of an access key
- Embedded - embed an account name and access key as parameters in the transformer
- Environment Variables - use credentials already configured on the system, in the environment variables AZURE_STORAGE_ACCOUNT and AZURE_STORAGE_ACCESS_KEY
Account
Available when the credential source is Web Connection. To create an Azure Storage connection, click the 'Account' drop-down box and select 'Add Web Connection...'.
The connection can then be managed via Tools -> FME Options... -> Web Connections.
Embedded Credentials
Account Name
Available when the credential source is SAS or Embedded. An account name and either an account key or a shared access signature can be specified directly in the transformer. |
Account Key
Available when the credential source is Embedded. An account name and access key can be specified directly in the transformer instead of in a web connection. |
Shared Access Signature (SAS)
Available when the credential source is SAS. An account name and shared access signature can be specified directly in the transformer. |
Action
Action
The type of operation to perform. Choices are:
The remaining parameters available depend on the value of the Action > Action parameter. Parameters for each Action are detailed below.
Parameters - Delete Action
Deletes messages from the queue.
Delete Messages Options
Queue
The queue to delete messages from. A queue can be entered manually, or selected interactively by clicking the ellipses.
Delete all Messages
If Yes, all messages in the queue will be removed. If No, the message with the specified ID and POP receipt will be removed. |
Message ID
Required for deleting a message. Retrieved from a previous receive operation. |
POP Receipt
Server Timeout (seconds)
The maximum time to wait for the server to complete the requested operation.
Parameters - Peek Action
Receives messages from the front of the queue without altering the visibility of the messages.
Peek Messages Options
Queue
The queue to peek at messages from. A queue can be entered manually, or selected interactively by clicking the ellipses.
Number of Messages
The number of messages to peek from the queue. |
Parameters - Receive Action
Receives messages from the front of the queue.
Receive Messages Options
Queue
The queue to receive messages from. A queue can be entered manually, or selected interactively by clicking the ellipses.
Mode
Two message receiving options are available:
- Stream: The connector continues to receive messages indefinitely. The translation needs to be terminated in order to stop reception.
- Batch: Receive a specified number of messages before the connection is closed.
Number of Messages
Specifies the number of messages to read for the operation. For
Stream mode, this is the number retrieved per poll interval. For Batch mode, this is the total number retrieved.
Poll Interval (seconds)
When mode is Stream, the period to wait between receiving messages.
Delete on Receive
If Yes, then delete the messages as soon as they are received from the queue. If No, the messages can be received again after the visibility timeout. |
Visibility Timeout (seconds)
The time the message is invisible. After the timeout expires, the message is visible. The default is 30 seconds. |
Parameters - Send Action
Send Messages Options
Queue
The queue to send messages from. A queue can be entered manually, or selected interactively by clicking the ellipses.
An encoded message. The default encoding is a xml unicode string. |
Update Messages
If Yes, update a message in the queue service. This operation can be useful to “lease” a message if the workspace has not finished processing. The invisibility of a message can be extended by updating the visibility timeout. |
Message ID
Required for updating a message. Retrieved from a previous receive operation. |
POP Receipt
Time to Live Expiry
If Yes, set the time that the message lives for. If No, the message never expires. |
Time to Live (seconds)
How long the message lives. The default and maximum is 7 days. After the specified time, the message is permanently removed from the queue. |
The time the message is invisible. After the timeout expires, the message is visible. The default is 0 seconds. |
Output Attributes
The following attributes can be selected for inclusion on the output features. Each output feature represents a message that was either sent or received.
_id
The id of a message. Required for updating and deleting. |
_value
The message
content. |
_dequeue_count
The number of times a message has been retrieved, either from a peek or receive operation.
_expiration_time
The time the message expires in unix time.
_pop_receipt
The POP receipt of a message, obtained from a receive operation. Required for updating and deleting.
_time_next_visible
The time the message is next visible in unix time.
_timestamp
The time the message was created in unix time. |
How to Set Parameter Values
Text Editor
Arithmetic Editor
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies |
Azure Storage account |
FME Licensing Level
FME Base Edition and above
Aliases |
MicrosoftAzureQueueStorageConnector |
History |
Released FME 2019.0
Categories |
Integrations
Web
Workflows
Search for all results about the AzureQueueStorageConnector on the FME Community.
