You are here: Reference Manual > FME Server Web Services > Transformation Services > Data Download Service > Examples
Example 1
Shows a Data Download service request with two published parameters and specifying XML as response format.
Request
http://localhost/fmedatadownload/Samples/austinDownload.fmw?
THEMES=airports&FORMAT_GENERIC=SHAPE&opt_responseformat=xml
Response
<?xml version="1.0" encoding="ISO-8859-1" ?>
<serviceResponse>
<!-- Service Status Info -->
<statusInfo>
<status>success</status>
<mode>sync</mode>
</statusInfo>
<!-- Service Return -->
<fmeTransformationResult>
<fmeEngineResponse>...</fmeEngineResponse>
<fmeServerResponse>...</fmeServerResponse>
</fmeTransformationResult>
<url>http://localhost/fmedatadownloadresults/FME_3368_1245953381697_3368871561115.zip</url>
<jobID>52</jobID>
</serviceResponse>
Example 2
A Data Download service request with one published parameter, one TM directive and specifying JSON as response format.
Request
http://localhost/fmedatadownload/Samples/austinDownload.fmw?THEMES=airports&tm_tag=high&opt_responseformat=json
Response
{"serviceResponse": {
"fmeTransformationResult": {
"fmeEngineResponse": {
"fmeServerResponse": {
"jobID": 8,
"statusInfo": {
"mode": "sync",
"status": "success"
"url": "http://localhost/fmedatadownloadresults/FME_5516_1258064613849_5516859449883.zip"
Example 3
A Data Download service request that specifies a requester’s e-mail address, service mode as async, and XML as the response format.
Request
http://localhost/fmedatadownload/Samples/austinDownload.fmw?opt_servicemode=async&opt_requesteremail=joe@safe.com&opt_responseformat=xml
Response
<?xml version="1.0" encoding="ISO-8859-1"?>
<serviceResponse>
<statusInfo>
<mode>async</mode>
</statusInfo>
<email>someone@safe.com</email>
<jobID>9</jobID>
</serviceResponse>
Example 4
Using the opt_showResult parameter set to false.
Request
http://localhost/fmedatadownload/Samples/austinApartments.fmw?opt_showresult=false&opt_responseformat=xml
Response
<?xmlversion="1.0"encoding="UTF-8"?>
<serviceResponse>
<statusInfo>
<mode>sync</mode>
</statusInfo>
<jobID>119</jobID><url>http://localhost/fmedatadownload/results/FME_7D150E1F_1317227595851_7460.zip
</url>
</serviceResponse>
Example 5
Using the opt_showResult parameter set to true.
Request
http://localhost/fmedatadownload/Samples/austinApartments.fmw?opt_showresult=true&opt_responseformat=json
Response
"statusInfo": {
"mode": "sync",
"status": "success"
"id": "120",
"jobStatus": "SUCCESS",
"statusNumber": "0",
"statusMessage": "Translation Successful",
"jobID": 120,
"url": "http://localhost/fmedatadownload/results/FME_7D150E1F_1317227687127_7460.zip"
Example 6
Specifying the Notification Service topic to notify when a job succeeds or fails, respectively.
http://localhost/fmedatadownload/Samples/austinApartments.fmw?&nm_jobsuccess_topic=DATADOWNLOAD_ASYNC_JOB_SUCCESS&nm_jobfailure_topic=DATADOWNLOAD_ASYNC_JOB_FAILURE
Example 7
This example schedules a data download request to run at a specified time. It includes a requester email address and a number of published parameters.
http://localhost/fmedatadownload/Samples/austinDownload.fmw?THEMES=airports%20cenart&COORDSYS=LL84&FORMAT_GENERIC=SHAPE&MINX=-100&MINY=25&MAXX=-90&MAXY=35&BBOX_COORDSYS=LL84&opt_showresult=false&opt_servicemode=schedule&opt_requesteremail=joe@safe.com&trigger=runonce&start=2013-02-15 16:45:00&category=schedcat&name=schedname&description=myscheduledrequest
See Also
