Administrator's Guide
Notices
Version Information
About This Guide
About FME Server
Planning an FME Server Installation
Choosing a Deployment Architecture
Planning for Security Updates
Planning for Scalability and Performance
About Component and Job Recovery
System Requirements
Requirements for FME Workspaces
Performing an Installation
Express Installation (Windows)
Express Installation (Linux)
Distributed/Fault Tolerant Installation
Distributed Engine Installation
Silent Installation (Windows)
Silent Installation (Linux)
Upgrading FME Server
Full FME Server Upgrade
FME Engine Only Upgrade
Optimizing FME Server
Configuring the Number of FME Engines to Start
Adding FME Engines on a Separate Machine
Changing the Database Provider for the FME Server Database
Moving the Web Applications Server to Another Machine
Securing FME Server
Security Basics
Configuring Integrated Windows Authentication
Troubleshooting Active Directory Configurations
Running the FME Server System Services Under Different Accounts
Using FME Server with a Proxy Server
Encrypting the FME Server Database Password
Hiding External Content in the Web User Interface
Other Common Tasks
Licensing and Administration
Backup, Restore, and Migration
Notifications
Workflow and Resources
Reference Manual
Notices
FME Terminology
FME Server Architecture
FME Server Ports
Directory and Account Permissions
FME Server Configuration Files
processMonitorConfigCore.txt
processMonitorConfigEngines.txt
fmeServerConfig.txt
fmeCommonConfig.txt
fmeWebSocketConfig.txt
FME Server Log Files
Message Logger Properties
API Quick-Find
FME Server Web Services
Transformation Services
Notification Service
Utility Services
Authentication and Authorization
FME Server Engines
Configuration File Layout
Pseudo Variables
Licensing the FME Engine
FME Server Core
Job Directives
Repositories
Resources
WebSocket Server
FME Server Process Monitor
FME Server Console
Starting the FME Server Console
Modes
Directives
Command Line Options
Web User Interface
FME Server Web Interface
Preparing to Use the Web Interface
Accessing the Web Interface
Account Management
Logging In to the Web Interfaces
Changing the Login Password
Logging Out
General Features
User Session Information
Server Information
About Times and Time Zones
Using the Interface
Home
Run Workspace
Jobs
Schedules
Repositories
Workspace Viewer
Notifications
Resources
Connections
Projects
Dashboards
Engines & Licensing
Security
System Cleanup
Backup & Restore
System Configuration
All Files
Installing for Fault Tolerance
Distributing Components (2-Tier)
Distributing Components (3-Tier)
You are here:
