You are here: Reference Manual > FME Server Configuration Files
Process Monitor
Filename: processMonitorConfigCore.txt
Purpose: Start and configure FME Server Core processes.
Filename: processMonitorConfigEngines.txt
Purpose: Sets the default FME Engines to start.
Note: To change the number of FME Engines to start, use the FME Server Web User Interface.
FME Server Core
Filename: fmeServerConfig.txt
Purpose: Configure various FME Server Core functions.
Filename: fmeCommonConfig.txt
Purpose: Configure FME Server security and the connection to the FME Server Database.
Filename: fmeWebSocketConfig.txt
Purpose: Configure the FME Server WebSocket Server.
FME Engines
Filename: fmeEngineConfig.txt
Purpose: Configure the FME Engines, including subsections, pre and post commands, and success and failure responses. For details, see Configuration File Layout.
FME Server Web Services
Filename: propertiesFile.properties
For example, if you are using the Apache Tomcat web application server that is provided with an Express installation of FME Server, the properties file for the Data Streaming service is located at:
<FMEServerDir>/Utilities/tomcat/webapps/fmedatastreaming/WEB-INF/conf/propertiesFile.properties
If your distributed installation of FME Server uses a separate web application server, the path to the FME Server service properties files is where your web application server stores .war files.
Purpose: Configure properties for the FME Server Web Services. Use this file to set the host for the service and other settings.
FME Server Console
Filename: FMEServerConsoleConfig.txt
Purpose: Configure the FME Server Console. Use this file to set the FME Server host used by the FME Server Console.
