SQLite Non-Spatial User Attributes
For information on the parameters in this dialog that are common to all readers, see:
For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name |
The name of the field to be written. Valid values for the field name are less than 255 characters, and include any SQL-valid characters (double-quotes " are the only invalid character in SQLite). |
Type |
The type of a column in a table. The valid values for the field type are listed below: blob float integer real(width, decimal) text varchar(width) |
Index |
The type of index to create for the column. If the table does not previously exist, then upon table creation, a database index of the specified type is created. The database index contains only the one column. The valid values for the column type are listed below:
