SQLite Non-Spatial Reader Parameters
Database Connections
Database formats include a Database Connection parameter that defines and stores authentication information. For general information about sharing database connections, please see Using Database Connections. Note that Database Connection parameters may differ slightly, depending on context and/or database format. |
Select an existing connection, or Add Database Connection to define a new connection.
The new connection can be made visible only to the current user, or can be shared among multiple users.
Database Connection
Enter the name of the SQLite3 database file.
Constraints
Click the Browse button and choose from the list of feature types.
Schema Attributes
- In a non-dynamic scenario, you can use this parameter to expose additional attributes on multiple feature types.
