OpenStreetMap (OSM) XML Writer: User Attributes
For information on the parameters in this dialog that are common to all readers, see:
For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name
The name of the column to be written.
Type
The type of a column in a table. The valid values for the column type are listed below:
