OpenStreetMap (OSM) XML Writer Parameters
Decimal Points
Number of Decimal Points
Controls the number of decimal points that will be written in the OSM file for the lat/long coordinates of OSM points.
The default is 7 decimal points.
Pretty Printing
Pretty Print
Setting this parameter to Yes ensures the output is neatly formatted. This promotes easier reading on screen and in print output. Note, however, that it also produces a considerably larger output file size due to the added whitespace.
- Indent Size: Select a value from 0 to 9.
- Replace Tabs with Spaces: By default the Tab character is used to for indentations. Select Yes to substitute the Tab character with a Space.
