Esri ArcGIS Layer Quick Facts
Format Type Identifier |
ARCGIS_LAYER |
Reader/Writer |
Reader |
Licensing Level |
Esri Edition |
Available on:
Dependencies |
Esri ArcGIS The bit version (32-bit or 64-bit) must be the same for FME and ArcGIS. |
Dataset Type |
Esri Layer/Feature Class |
Feature Type |
Typical File Extensions |
Automated Translation Support |
Yes |
User-Defined Attributes |
Yes |
Coordinate System Support |
Yes |
Generic Color Support |
Yes |
Spatial Index |
Optional |
Schema Required |
Not applicable |
Transaction Support |
Not applicable |
Geometry Type |
geodb_type |
| Encoding Support | No |
Esri ArcGIS Layer Geometry Support
Geometry |
Supported? |
aggregate |
yes |
circles |
yes |
circular arc |
yes |
donut polygon |
yes |
elliptical arc |
yes |
ellipses |
yes |
line |
yes |
none |
yes |
point |
yes |
polygon |
yes |
raster |
no |
solid |
no |
surface |
no |
text |
yes |
z values |
yes |
