Esri ArcGIS Layer Feature Representation
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
The ArcGIS Layer modules make use of the following special attribute names.
Attribute Name |
Contents |
geodb_type |
The type of geometric entity stored within the feature. The valid values are listed below:
For a description of the attributes belonging to each of the different geodb_type’s, please see the chapter Esri Geodatabase Reader/Writer. |
geodb_feature_is_simple |
Indicates whether or not the geometry is simple. |
Features read from a dataset also have an attribute for each attribute in the layer/feature class.
