You are here: Workbench Basics > About the FME Data Inspector > Data Inspector Interface > Menu Commands and Shortcuts
Menu, Toolbar, and Shortcuts
FME Data Inspector
Command Keyboard Shortcut Function
Preferences
Opens the FME Options dialog for configuring optional Data Inspector features, including Background Maps, Database Connections, Default Paths, and Web Service Connections.
File
Open Dataset
Ctrl+O
Opens a file browser so you can pick a dataset.
Open Recent   Displays a list of the most recently viewed files.
Add Dataset
Ctrl+D
Opens a file browser so you can add a dataset to the current view.
Close View
Ctrl+F4
Closes the current view.
Save Data As
Ctrl+S
Saves the current view to a separate dataset. See Saving Data.
Save Selected Data As
Ctrl+Alt+S
Saves selected features to a separate dataset. See Saving Data.
Exit Ctrl+Q Shuts down the FME Data Inspector.
View
Windows
Provides options to show or hide the following parts of the user interface:
  • Display Control
  • Feature Information
  • Log
  • Table View
  • Status Bar
  • Toolbar
  • Tab Bar
Table View
2D
3D
Ctrl+1
Ctrl+2
Ctrl+3
Toggle between table, two-dimensional and three-dimensional views.
See Viewing Data in Table Mode and Viewing Data in 2D or 3D Mode.
Background Color
Ctrl+B
Opens a dialog for selecting a new background color in the View window.
Display Full Precision
When checked, floating point values display up to 17 significant digits in the Feature Information window and Table View. When unchecked, Data Inspector attempts to display floating point values shorter (up to 11 significant digits) if doing so makes the string significantly shorter. Otherwise, 17 digits are displayed. For example, when unchecked, the value 1234.0001000000002 would display as 1234.0001. However, the value 12345678901234567e-17 would remain the same. This setting affects only the display of values; it does not affect any internal numeric calculations, which FME performs using the maximum precision.
Note: Changing this setting can also apply to the display of floating point values in the Log window, when Saving Data using Log This Feature. However, you must exit and restart Data Inspector for the change to take effect.
Mark End Nodes   Marks the starting and ending coordinates of features that appear in the View window in 2D mode. To use this tool more selectively, right-click on a node in the Display Control. For more information, see Viewing Start and End Coordinates.
Mark Coordinates   Marks the coordinates of features that appear in the View window in 2D mode. To use this tool more selectively, right-click on a node in the Display Control. For more information, see Marking Coordinates.
Mark Text Insertion Points   Marks the text insertion points of features that appear in the View window in 2D mode. To use this tool more selectively, right-click on a node in the Display Control. For more information, see Marking Text Insertion Points. To use this tool more selectively, right-click on a node in the Display Control
Allow Area Filling   When unchecked, feature type geometries with areas do not render an area filling when viewing features in the View window in 2D mode, regardless of any Fill Color or Fill Opacity settings. To use this tool more selectively, right-click on a node in the Display Control.
Refresh
F5
Reload the data from the source.
The Data Inspector will close the dataset and re-read everything in it from the source folder.
Any changes that have been made to the source dataset since it was opened in the Data Inspector will be updated in the View window when the dataset is refreshed.
Note: Do not use the Refresh button when you are viewing data routed directly from FME Workbench.
Stop
Esc
Cancel the current dataset being loaded or the current "Save" operation.
Camera
Command Keyboard/ Mouse Shortcut Function
Pan Mode
Ctrl+N
Press and hold both the left and right mouse buttons.
Move the camera view vertically and horizontally. Click and drag the pointer to pan the current dataset.
Orbit Mode
Ctrl+R
Hold down the middle mouse button.
Rotate a 3D image in the View window to inspect it from many different angles.
Note that this command is not available in 2D view mode.
Zoom In Mode
Ctrl++
Hold down the Shift key.
Moves the view closer, by increments, or farther away, by increments.
Tip: You can zoom in and out in the View window without activating the zoom tools by using the scroll wheel on your mouse.
The zoom tools are location aware, in other words, they draw the focus of the view to where you click or to your mouse location when using the scroll wheel to zoom.
Zoom Out Mode
Ctrl+-
Hold down the Ctrl key.
Zoom to Selected Feature
Ctrl+L
Concentrates the view on the selected feature.
Zoom to Full Extent
Ctrl+E
Zooms the view to a distance so that the data is visible and centered in the window.
Tools
Select
Ctrl+K
Selects a feature, and displays information in the Feature Information window.
Select All Features with No Geometry
Ctrl+G
Selects all features that have no geometry (for example, a database record may consist entirely of features that have an fme_type of fme_no_geom).
Filter Features Opens the Filter Features dialog for displaying only features that satisfy a set of filter conditions.
Mark Location Opens the Mark Location dialog for Marking a Location in a View.
Measure Distances
Ctrl+M
Enables the measuring tool. Click and drag between two points in the View window to measure the distance between them.
Stereo Mode
Off: Turns off any stereo effect, bringing the display image back to the original 2D default.
Anaglyphic: Gives the display image a stereoscopic 3D effect when viewed with glasses with a red left lens and a cyan right lens.
The display image will consist of two superimposed color layers offset with respect to each other to produce a depth effect.
FME Options Opens the FME Options. In Data Inspector, FME Options provides access to Background Map, Default Paths, Database Connections, and Web Connections.
Window
If more than one view is open, this menu switches the focus of the tabs in the main window.
Help
Use Offline Help
By default, when you access Help from any FME Desktop tool (FME Workbench, FME Data Inspector, and others), it is opened from the safe.com website. This means that you will always see the latest help topics for updates and for new features.
You can change this default behavior and access product documentation from the help files that are installed locally (for example, if Internet access is unreliable or is not available).
