Modifying Feature Types to Read
This reader parameter allows you select the feature types to read. You can set up an FME translation and run the workspace on a subset of the defined layers.
Note: You can also do this by deleting or disabling unwanted feature types before running the workspace. However, this can sometimes mean editing and re-editing the workspace to return it to its original state.
In the Navigator, expand the reader Parameters > Features to Read, and right-click on Feature Types to Read. Then click Modify Feature Types List.
You can choose feature type names from a static list that is built from the feature types that already exist in the workspace for the given dataset. ( However, if you have previously chosen to Merge Feature Types, there may be only one feature type in the workspace.) If the value of this parameter is <not set>, then all feature types in the workspace will be read.
From the List menu, you can:
You can also use the +/- buttons to add or remove list items.
After you press OK, Workbench will build a new static list of Feature Types To Read.
Publishing the Feature Types to Read Parameter
By publishing the parameter, you can select which features to read at run-time (for example, by a user who runs the workspace via an FME Server web page).
Right-click on the parameter and select Create User Parameter:
Check the Use Alternate Display Name box to assign an alias to each feature type name. If you have a long list, this can make it easier to identify feature types at runtime.
List: See above table for explanations of display options.
Parameter Definition (optional) |
Name: Change the name of the Published Parameter. Prompt: Enter the prompt to display at runtime. Default Value: If applicable, assign a default value for the parameter. |
Click the OK button to publish the parameter. The icon in the Navigator will change to indicate that the parameter is now published:
You can always modify the list by right-clicking on the Published Parameter in the Navigator and selecting Modify Feature Types List.
