You are here: Other Workbench Tasks > Working with FME Server > Publishing to FME Server
Note: To publish workspace templates to FME Server, see Saving a Workspace as a Template.
Open the workspace you want to publish. Click File > Publish to FME Server..., or click the button on the Workbench toolbar.
The Publish to FME Server wizard opens. Proceed through the panels of the wizard:
Note: To publish to FME Server, you must have an FME Server configured and available. For information, contact your System Administrator.
Publishing Between Versions of FME Desktop and FME Server
Safe supports publishing between versions of FME Desktop and FME Server in which the service pack (2014 and previous) or "first" point (2015 and later) versions match. For example:
FME Desktop Version
FME Server Version
Supported
2014 SP1
2014 SP1
Yes
2014 SP1
2014 SP5
No
2015.1
2015.1
Yes
2015.0
2015.1
No
2015.1.1
2015.1.2
Yes
See Also
