Smart Delete
If you delete a transformer from a workspace, FME will try to repair any connections from the deleted transformer. For example, deleting the LineOnArea transformer below repairs the connections in the workflow, and reconnects to the transformer on the right:
Select the transformer and press the Delete key, or right-click and select Delete from the command menu.
The repaired connections are highlighted green. Clicking anywhere in the workspace removes the highlight.
To delete a transformer without repairing the connections, press Shift + Delete.
Note: Workbench cannot repair connections where there is a many-to-many relationship between incoming and outgoing connections.
