Reader Directives: Raster Dataset
These directives are used when reading a mosaic dataset using the raster dataset reader.
MOSAIC_METHOD
Required/Optional
Optional
Values
None | By Attribute | Closest to Center | Lock Raster | North-west (default) | Seamline
Workbench Parameter
Mosaic Method
MOSAIC_ORDER_FIELD
Workbench Parameter
Order Field
MOSAIC_ORDER_BASE_VALUE
Required/Optional
Optional
Values
Any real number (default 0)
Workbench Parameter
Order Base Value
MOSAIC_LOCK_RASTER_ID
This directive lists the ObjectIDs as a comma-separated list that will be used to give the order of the rasters when the value of MOSAIC_METHOD is set to ‘Lock Raster’.
Required/Optional
Required when MOSAIC_METHOD is set to ‘Lock Raster’
Values
Comma-separated list of Raster ObjectIDs
Workbench Parameter
Lock Raster ID
MOSAIC_ORDER
Required/Optional
Optional
Values
Ascending (default) | Descending
Workbench Parameter
Lock Raster ID
MOSAIC_OPERATOR
Required/Optional
Optional
Values
First (default) | Last | Min | Max | Mean |Blend
Workbench Parameter
Mosaic Operator
NODATA_HANDLING_FOR_MANAGED_RASTERS
Required/Optional
Optional
Values
None | Single Alpha Band (default)
Workbench Parameter
Nodata Handling for Managed Rasters
