LDAP/Active Directory Reader (Technology Preview)
Licensing options for this format begin with FME Professional Edition.
The LDAP / Active Directory reader module provides FME with access to attribute data held on LDAP servers.
Technology Preview
Note: This format is still under active development, so please expect changes to the current behavior. We do not recommend using this format in production environments.
When creating queries or WHERE clauses, you will require a special subset of SQL. See the JDBC > LDAP Bridge for the full syntax and documentation.
