You are here: Popular Formats > Esri Geodatabase Reader/Writer > Writer Workbench Parameters > Esri Geodatabase (File Geodb ArcObjects) Writer Parameters
Esri Geodatabase (File Geodb) Writer Parameters
Note: The values populated in this parameter box set the values for writer parameters and for feature type parameters. Since some feature type parameters have equivalent writer-level parameters, the parameter box value will be used in two places.
The feature type parameters take precedence over writer parameters. The only time the writer-level parameters will be used is when there is no equivalent feature type parameter, or if the parameter was not supplied.
Database Connection
Geometry Settings
Advanced
