Post-Configuration Scripts
After configuring the database, you must run additional post-configuration scripts to finish completing the installation. These scripts enable the installed services, sample workspaces, and notification subscribers.
- Ensure that FME Server is running. For more information, see:
- (PostgreSQL database only) On the machine on which the FME Server database server is installed, open
<PostgreSQLDir>\data\pg_hba.conf.- Change the following lines:
- Restart the FME Server Database service.
host all all 127.0.0.1/32 md5
host all all ::1/128 md5
to:
host all all 0.0.0.0/0 md5
host all all ::/0 md5
- Run the following scripts:
- Windows:
- Linux:
- On the machine on which the FME Server Web Services are installed (Install the FME Server Web Services and Configure for Failover):
- <FMEServerDir>/Clients/utilities/configureDemoWorkspaces.sh
- <FMEServerDir>/Clients/utilities/addServices.sh
- On the machines on which the FME Server core is installed (primary and failover) (Install the FME Server Core and FME Engines):
- <FMEServerDir>/Clients/utilities/addSubscribers.sh
- <FMEServerDir>/Clients/utilities/addPublishers.sh
- <FMEServerDir>/Clients/utilities/addCleanupTasks.sh
- Restart the FME Server Core and FME Server Engines System Services.
On the machines on which the FME Server Core is installed (primary and failover) (Install the FME Server Core and FME Engines), open <FMEServerDir>\Utilities\, and run runPostInstall.bat.
Note: You may need to run this script as administrator (right-click and select Run as administrator).
