Back Up Configuration from FME Server 2014 and Later
To back up an FME Server 2014 or later configuration, perform the following:
- Back up the FME Server Configuration Files
- Back up the FME Server 2014 or Later Configuration
Note: Before proceeding, be sure to note your product's serial number. It may be required when you restore the configuration to the upgraded FME Server. You can find the serial number at the top of the Engines & Licensing page of the Web User Interface.
Note: To back up a configuration of an FME Server 2013, see Back Up Configuration from FME Server 2013.
Back Up the FME Server Configuration Files
Before proceeding with the primary task of backing up your FME Server configuration, we recommend manually backing up the FME Server Configuration Files to a location outside of your FME Server installation directory, in case you need to refer to them later. These files contain configurations for the FME Server Database and miscellaneous settings for the Transformation and Repository Managers. These configurations are not included in the primary backup procedure. To restore any changes that were made in these files, you must be able to refer to them when the upgrade is complete, so that you can make the corresponding changes in the replacement file.
WARNING: Configuration files from a backed-up FME Server are for reference only. Do not copy them to the corresponding directory of a restored FME Server.
The FME Server Web User Interface makes it easy to back up your FME Server 2014 and later configuration. For information about what is included in a backup, see Which FME Server Configuration Components are Migrated?.
Note: Backing up job history is not supported.
To perform the backup, use the Web User Interface tool.
Note: To restore your configuration after you upgrade FME Server, see Restore Configuration from FME Server 2014 and Later.
