Microsoft Azure Storage Table: Add Web Connection
This topic contains steps for defining a new connection. To reuse an existing connection, you can select it from the Microsoft Azure Storage Table Reader Parameters or Microsoft Azure Storage Table Writer Parameters.
Microsoft Azure Storage Connection
Web Service
Connection Name
Enter a name for the new connection.
Microsoft Azure Storage Parameters
The web service uses the following parameters.
Account Name
The name of the Microsoft Azure storage account to use.
Account Key
The secret access key for the account. Azure provides a primary and a secondary key for each account – either one can be used here.
Note  If you specify an account key for the web connection, do not provide an SAS token.
SAS Token
An SAS Token with permissions to access the account’s Azure Storage Tables.
Note  If you specify an SAS for the web connection, do not provide an account key.
