Microsoft Azure Storage Table Reader Parameters
About Web Connections |
Connections store authentication information. For general information about web connections, please see Using Web Connections. For information about managing web services (including authorization credentials such as Client Id and Client Secret), please see Managing Web Services. Connection From the Connection parameter in a web service format, you can do one of the following:
Microsoft Azure Storage Connection
Select an existing Microsoft Azure Storage connection, or Add Web Connection....
Add Microsoft Azure Storage Connection To define a new connection from the Connection parameter in a Microsoft Azure Storage Table format, see the topic Microsoft Azure Storage Table: Add Web Connection. |
Constraints
Specifies the name of the table to read data from. The table name can be entered manually or chosen from a list of tables accessible by the account specified by the Storage Service Name.
Specifies the filter applied to the Azure Storage Table query. The format of the filter is the same as the $filter clause for OData.
Logical Operator |
Description |
Example Filter String |
eq |
Equal |
City eq 'Redmond' |
| gt |
Greater than |
Price gt 20 |
ge |
Greater than or equal to |
Price ge 10 |
lt |
Less than |
Price lt 20 |
le |
Less than or equal |
Price le 100 |
ne |
Not equal |
City ne 'London' |
and |
And |
Price le 200 and Price gt 3.5 |
or |
Or |
Price le 3.5 or Price gt 200 |
not |
Not |
not isAvailable |
For a full filter syntax reference, please see Constructing Filter Strings for the Table Designer.
Schema Generation
This option can be set to prevent FME from unnecessarily reading all the rows from a potentially large file when determining its schema.
The default is 1.
Advanced
- Yes (default) – Ensures that a URL's digital certificate is valid (signed by a trusted certificate authority), trusted, and belongs to the domain to which you are connecting.
- No – Verification will not be performed (that is, there is no verification that the URL’s certificate is valid or trusted).
How FME Processes Multiple Verification Parameters in a Workspace
FME evaluates the setting at the workspace component level. If a reader/writer or web connection has the Verify HTTPS Certificate(s) parameter set to Yes, and an HTTPCaller transformer has the Verify HTTPS Certificate(s) parameter set to No, then the reader will verify certificates for its data requests, but the transformer will not verify certificates for its own requests.
FME does not combine multiple verification parameters — it uses the parameter local to the reader/writer, transformer, or web connection that is making the web call.
It is good practice to ensure that all Verify HTTPS Certificate(s) parameters in a workspace are set to Yes.
- On MacOS, requests to some servers will not work unless this parameter is set to Yes.
- The value of the Verify HTTPS Certificate parameter takes priority over the value of the Verify SSL Certificates parameter, which may be defined by the Web Connection used with this format.
Schema Attributes
Use this parameter to expose Format Attributes in FME Workbench when you create a workspace:
- In a non-dynamic scenario, this parameter allows you to expose additional attributes on multiple feature types. Click the browse button to view the available format attributes (which are different for each format) for the reader.
