Microsoft Azure Storage Table Writer Parameters
About Web Connections |
Connections store authentication information. For general information about web connections, please see Using Web Connections. For information about managing web services (including authorization credentials such as Client Id and Client Secret), please see Managing Web Services. Connection From the Connection parameter in a web service format, you can do one of the following:
Microsoft Azure Storage Connection
Select an existing Microsoft Azure Storage connection, or Add Web Connection....
Add Microsoft Azure Storage Connection To define a new connection from the Connection parameter in a Microsoft Azure Storage Table format, see the topic Microsoft Azure Storage Table: Add Web Connection. |
Advanced
Specifies which SQL operations will be performed by default by this writer. This default writer-level value can be overwritten at the feature type or table level.
- Insert – Allows for only Insert operations.
- Update and Delete – These writer modes can be overwritten at the feature type level.
- Yes (default) – Ensures that a URL's digital certificate is valid (signed by a trusted certificate authority), trusted, and belongs to the domain to which you are connecting.
- No – Verification will not be performed (that is, there is no verification that the URL’s certificate is valid or trusted).
How FME Processes Multiple Verification Parameters in a Workspace
FME evaluates the setting at the workspace component level. If a reader/writer or web connection has the Verify HTTPS Certificate(s) parameter set to Yes, and an HTTPCaller transformer has the Verify HTTPS Certificate(s) parameter set to No, then the reader will verify certificates for its data requests, but the transformer will not verify certificates for its own requests.
FME does not combine multiple verification parameters — it uses the parameter local to the reader/writer, transformer, or web connection that is making the web call.
It is good practice to ensure that all Verify HTTPS Certificate(s) parameters in a workspace are set to Yes.
- On MacOS, requests to some servers will not work unless this parameter is set to Yes.
- The value of the Verify HTTPS Certificate parameter takes priority over the value of the Verify SSL Certificates parameter, which may be defined by the Web Connection used with this format.
