FME Form: 2026.3
Data Caching
Data caching seamlessly integrates the workspace with Data Preview or the FME Data Inspector. When enabled, output ports record feature data in temporary caches, which you can view and inspect after completing a full or partial translation, or even mid-translation.
Data caching is enabled by default. If it is disabled, do any of the following to re-enable:
  • From the Menu Bar, select Run > Enable Data Caching.
  • On the Toolbar, click the Caching icon, or expand the Run icon and select Enable Data Caching.
  • Enter Ctrl+F5.
  • Set the Enable Data Caching workspace parameter.
This example workspace shows the canvas with generated caches after a workspace is run with data caching enabled:
To view cached features, click a cache icon on an output port. Complete caches are available to view after a translation runs successfully. Caches can also be viewed while a translation is still running. While running, all cache previews are refreshed each time an additional cache is selected for viewing.
Note  Record counting works implicitly when data caching is enabled.
The coloring of icons varies depending on the state of the cache, as follows:
Cache Icon
Cache Icon When Clicked for Viewing
Meaning
Meaning When the Icon is Animated
The translation completed successfully and a complete cache is available to view.
The translation is running and a cache is available to view before completion.
The translation stopped and a cache that is considered stale is available to view. For more information, see Stale and Incomplete Caches (below).
The translation is running and a cache that is considered stale is available to view before the translation completes. For more information, see Stale and Incomplete Caches (below).
The translation stopped or failed and an incomplete cache that is considered up-to-date is available to view. For more information, see Stale and Incomplete Caches (below).
Viewing Data Caches: Data Preview or FME Data Inspector?
The cached data at the selected port is presented in the Data Preview pane or the FME Data Inspector, depending on your Data Inspection setting in Utilities > FME Options > Workbench.
Cache viewing in FME Data Inspector has some limitations. Unlike the Data Preview pane, FME Data Inspector does not notify you if the cache you are viewing has changed due to translation status changes in FME Workbench. These changes include:
  • If a translation is still running, and a more up-to-date cache has been generated.
  • If you re-ran the translation after modifying the workspace.
In both cases, to view the latest cache, you must return to FME Workbench and click on the cache icon again.
Limitations of Data Caching
When data caching is enabled, keep in mind the following:
  • Data caching affects system resources, and because all features are recorded and stored, it can also affect disk space. You may not want to keep all workspaces in this mode. Alternatively, consider Running and Inspecting Part of a Workspace (below) or Skip Caching in Collapsed Bookmarks (below).
  • Data caches do not maintain input feature order, such as when workspaces run from multiple caches, or transformers run in Group Processing mode that specifies Complete Groups: When Group Changes (Advanced). To avoid unexpected results, place a junction before the location in the workspace where you expect a specific order, and use the junction as the basis for starting or stopping a partial translation (see Running and Inspecting Part of a Workspace, below).
  • To generate separate translation log files for each process of a translation that runs multiple processes, data caching must be off.
You can select one or more objects on the canvas, and run only part of a workspace for inspection. Large workspaces, especially those that access large data sets, can take time to run in full. Running a partial workspace can save time and resources when:
  • You make a change to a workspace, and you want to see quickly how the change affects your data.
  • You are preparing data for input, and you want to see quickly how it looks.
You can run partial workspaces in the following ways:
  • Run From This (or Selected) (F6): All parts of the workspace that flow from a selected object (or objects) run. Required upstream nodes without up-to-date caches are also run.
  • Run Just This (or Selected) (Ctrl+Alt+F6): Only a selected object (or objects) runs. If a collapsed bookmark is included in the selection, only the objects within the bookmark run. Required upstream nodes without up-to-date caches are also run.
  • Run To This (or Selected) (Shift+F6): All parts of the workspace that flow to a selected object (or objects) run.
  • Run Between Selected (Ctrl+Shift+F6): All parts of the workspace that flow between the selected objects run. Required upstream nodes without up-to-date caches are also run.
These options are available in the mini-toolbar above any selected canvas object, under Run > Run Selected on the Menu Bar, under Run on the Toolbar, or as keyboard shortcuts (noted above).
Working with Data Caches - Other Considerations
A data cache is considered stale if you make a change to the workspace, after or during translation, that invalidates one or more caches. If a workspace fails or is manually stopped mid-translation, the incomplete cache that results may be considered stale depending on the cache settings of the workspace (below).
If a workspace is re-run, stale caches always regenerate if required for downstream translation.
A data cache is considered incomplete if the corresponding object is part of a failed or manually stopped translation.
The following settings, located under Run on the Menu Bar or Toolbar, instruct FME on how to treat incomplete caches when you re-run the workspace.
  • Regenerate Incomplete Caches (Mark as Stale) (default): When the workspace re-runs, incomplete caches are regenerated if required for downstream translation.
  • Use Incomplete Caches (Mark as Up-to-date): When the workspace re-runs, incomplete caches are considered up-to-date and not regenerated.
    Note  When this setting is applied, and incomplete caches are present, the Run icon on the toolbar appears as .
Alternatively, you can configure the equivalent settings through the Incomplete Cache Handling workspace parameter.
Note  When a workspace with existing data caches is run, FME includes any up-to-date caches in the run as required, but their corresponding objects do not run as part of the overall translation. To run the entire workspace and regenerate all caches, including up-to-date ones, specify Run > Run Entire Workspace (Shift + F5).
Tip  Use Junctions to create caches where data either merges, or diverges in separate streams, as a useful starting point for partial runs.
Cache Icons and Their Meanings
The coloring of cache icons indicates whether they are considered complete, stale, or incomplete and up-to-date.
Cache Icon
Meaning
To conserve resources, you can prevent FME from caching portions of a workspace, if you know those portions do not require caching for producing accurate runs. Place the parts of the workspace you do not want to be cached in a bookmark, then collapse the bookmark. Any ports inside the collapsed bookmark that do not output features to components outside of the bookmark will not produce caches.
Clearing Caches
When a workspace containing data caches reruns, FME clears the cache at the point where the run originates, and all downstream caches. This clearing occurs at the start of the run.
To assist in troubleshooting, you can clear individual data caches manually before rerunning a workspace in data caching mode. When you clear the cache of a selected reader or transformer, the cache of that item, and all caches downstream of that item, are cleared. When you clear the caches of items in a selected bookmark, the caches of all items within the bookmark, and all caches downstream of those items, are cleared. To clear caches, right-click on a reader, transformer, or bookmark, and select Clear Data Cache.
Warning  Clearing data caches is a permanent operation. It cannot be reversed through the Edit History Window.
Viewing and Controlling Caching Mid-Translation
You cannot enable data caching during a translation, or re-enable caching after disabling it mid-translation. If you disable caching mid-translation, caches are removed.
