FME Flow: 2025.2
Before Installation
Before you install the FME Flow components for a 2-tier system, ensure that:
- The following non-FME Flow components are in place on your network:
- Database server on a separate machine.
- File system on a separate machine.
- Web application server, only if you want to use your own Apache Tomcat web application server, instead of the one provided with the FME Flow installer.
- The necessary ports are available on your network. Firewalls must permit certain ports to be opened between nodes. For more information, see FME Flow Ports.
Next Steps
Proceed to Obtain the Installer.
