FME Transformers: 2026.2
Categories
Calculated Values
Spatial Analysis
Related Transformers
NetworkFlowOrientor
ShortestPathFinder
StreamOrderCalculator
StreamPriorityCalculator
NetworkTopologyCalculator
Finds the connected lines that belong to the same network graph.
Network Topology in FME
In order to successfully generate a network topology, some conditions must be met.
  • Lines must touch (be snapped) at an end vertex - first or last.
  • Lines must be split at junctions. The TopologyBuilder can automate this process, but will not consider z-values (and so may not produce correct results for overpasses/underpasses, for example.)
  • A junction at an interior vertex (not an end vertex) produces a complex edge, which is not supported.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases NetworkTopologyBuilder
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the NetworkTopologyCalculator on the FME Community.
