FME Transformers: 2026.2
Categories
Geometries
Spatial Analysis
AnchoredSnapper
Brings lines, segments, end points or vertex points of features together if they are within a certain distance of each other, where one set of features is non-moving.
The difference between the AnchoredSnapper and the Snapper is that anchor features are considered to be accurate and consequently do not move.
  • Any feature that undergoes dimensional collapse as a result of being snapped will be output through the Collapsed port.
  • A short cleanup step is performed after snapping. This step will remove duplicate points, and may create aggregates to preserve overlapping, directed segments.
  • Features with geographic coordinates (latitude/longitude) will likely need to be reprojected to a coordinate system with real-world ground units (such as meters) to match the Snapping Distance parameter value.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases FixedSnapper BaseSnapper
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the AnchoredSnapper on the FME Community.
