FME Transformers: 2026.1
Categories
Geometries
Related Transformers
2DArcReplacer
2DEllipseReplacer
ArcEstimator
ArcPropertyExtractor
ArcPropertySetter
Creator
EllipsePropertyExtractor
EllipsePropertySetter
Modifies or creates ellipse geometry according to new coordinate, radii, rotation, or orientation values.
Jump to Configuration
  • Modifying ellipse or circle geometry
The EllipsePropertySetter receives features with ellipse or point geometry. Ellipses are modified if any values provided in parameters differ from the input geometry. Points are converted to ellipses if at least a New Primary Radius value is provided.
The parameters may modify or create an ellipse as a closed Arc By Center Point by the following:
  • Center X, Y, and Z coordinates
  • Primary and Secondary Radius in ground units
  • Rotation in degrees
  • Orientation
  • An assumed sweep of 360 degrees
Values may be entered or provided through attribute values, expressions, or user parameters.
Features without valid ellipse or point geometry will be rejected, as will points that do not have the required parameter values to create an ellipse.
For more information on ellipse geometry see Ellipse.
Creating and Modifying Arcs, Circles, and Ellipses
These transformers work with arcs in a variety of ways.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the EllipsePropertySetter on the FME Community.
