FME Transformers: 2026.1
Categories
Geometries
Related Transformers
2DArcReplacer
2DEllipseReplacer
3DArcReplacer
ArcEstimator
ArcPropertyExtractor
ArcStroker
Creator
Curvefitter
EllipsePropertyExtractor
EllipsePropertySetter
ArcPropertySetter
Modifies or creates arc geometry according to new coordinates, angles, radii, or rotation values.
Jump to Configuration
  • Modifying arc geometry
  • Converting points to arcs
The ArcPropertySetter receives features with arc or point geometry. Arcs are modified if any values provided in parameters differ from the input geometry. Points are converted to arcs if at least Primary Radius, Start Angle, and Sweep Angle values are provided. The point’s coordinates are used as the arc’s center.
The parameters may modify or create an arc as an Arc By Center Point or Arc by 3 Points by the following:
  • Center X, Y, and Z coordinates
  • Start and End X, Y, and Z coordinates
  • Primary and Secondary Radius in ground units
  • Rotation in degrees
  • Start Angle and Sweep Angle in degrees
Values may be entered or provided through attribute values, expressions, or user parameters.
Features without valid arc or point geometry will be rejected, as will points that do not have the required parameter values to create an arc.
For more information on arc geometry and types, see Arc.
  • To extract arc properties to use in expressions, use an ArcPropertyExtractor before the ArcPropertySetter.
Creating and Modifying Arcs, Circles, and Ellipses
These transformers work with arcs in a variety of ways.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the ArcPropertySetter on the FME Community.
