FME Transformers: 2026.1
Categories
Geometries
Related Transformers
2DArcReplacer
ArcEstimator
ArcPropertyExtractor
ArcPropertySetter
ArcStroker
Bufferer
Creator
Curvefitter
EllipsePropertyExtractor
EllipsePropertySetter
2DEllipseReplacer
Replaces or creates feature geometry with a 2D ellipse as defined in parameters for center point, radii, and rotation.
Jump to Configuration
  • Creating ellipse or circle geometry from attribute values or user parameters
  • Replacing point geometry with ellipses or circles defined by values
The 2DEllipseReplacer receives features of any kind and replaces their geometry with ellipses as defined in parameters.
The parameters describe an ellipse as a closed Arc By Center Point by the following:
  • Center X and Y coordinates
  • Primary and Secondary Axis (radii) in ground units
  • Rotation in degrees
  • An assumed sweep of 360 degrees
Values may be entered or provided through attribute values, expressions, or user parameters.
If the feature has point or ellipse geometry, and Center X and Y are left blank, the coordinates of the feature’s existing geometry will be used. If the feature has no geometry or geometry other than point or ellipse, the feature is rejected.
For more information on ellipse geometry see Ellipse.
  • To create circles around point features, consider using a Bufferer.
Creating and Modifying Arcs, Circles, and Ellipses
These transformers work with arcs in a variety of ways.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the 2DEllipseReplacer on the FME Community.
