FME Transformers: 2026.1
Categories
Data Quality
Geometries
Related Transformers
AreaOnAreaOverlayer
Snapper
AreaGapAndOverlapCleaner
Repairs area topologies by resolving gaps and overlaps between adjacent areas.
Jump to Configuration
  • Cleaning topology errors in a polygon coverage to create a single, contiguous surface.
The AreaGapAndOverlapCleaner receives features with valid area geometry and cleans up shared boundaries by dissolving overlaps and filling in gaps between polygons.
Input aggregate geometry may be either deaggregated or rejected.
Z values and measures are supported.
Repairing Overlaps and Gaps
Overlaps and gaps are processed slightly differently.
Both use the Tolerance and Repair Method parameters to determine how they are resolved. Gaps are further handled according to the Fill All Gaps parameter.
Overlaps are all processed, all the time. If the overlap is within the Tolerance distance, the repair is done automatically. If the overlap is greater than the tolerance, the Repair Method choice is used.
Gaps within the Tolerance distance are repaired automatically. If Fill All Gaps is Yes, gaps greater than the tolerance are repaired according to the Repair Method choice. If Fill All Gaps is No, they are not repaired.
Fill All Gaps
Within Tolerance
Greater Than Tolerance
Overlaps
Automatic
Per Repair Method
Gaps
No
Automatic
Untouched
Gaps
Yes
Automatic
Per Repair Method
Tolerance
Tolerance is a distance in the ground units of the features’ coordinate system. The choices are to enter a value or choose Automatic.
For most transformers with a Tolerance parameter, Automatic is recommended, but it is frequently not the correct choice here. Automatic will calculate a value that accounts for minute differences introduced by binary limitations, rounding errors, and the like (See Geometry Concepts > Tolerance). The calculated value is written to the log file.
Tolerance is always greater than zero.
Tolerance > Automatic does not consider the size of gaps and overlaps present in the data. For many use cases, this value is too small and an explicit value should be entered. The value should be guided by the nature of the input geometry (size of gaps and polygons) and whether you want the repairs to be automatically handled or determined by a specific Repair Method.
Repair Method
Gaps and overlaps greater than the Tolerance value are repaired according to the Repair Method:
  • Longest Boundary: Gaps and overlaps are allocated to the area with the longest boundary.
  • Random: Gaps and overlaps are allocated to areas selected at random.
  • Priority (Edge Preserving): Gaps and overlaps are allocated according to a numeric priority attribute:
    • Overlaps go to the higher priority area.
    • Gaps go to the lower priority area.
    • The boundary of the higher priority area is preserved.
  • Priority (Area Enlarging): Gaps and overlaps are allocated according to a numeric priority attribute:
    • Both overlaps and gaps go to the higher priority area.
    • The higher priority area may be enlarged.
When using Priority methods, zero (0) is the highest priority. If there is a conflict where more than one area has the same priority, one is selected arbitrarily.
  • When unexpected results are output, it can often be corrected by adjusting the Tolerance value.
  • To repair only overlaps (not gaps), consider using a Dissolver.
  • Invalid area geometry such as self-intersecting or degenerate polygons will not be rejected, but will not be repaired properly.
  • Donut holes are gaps, and may be processed accordingly.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies
Aliases SliverRemover
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the AreaGapAndOverlapCleaner on the FME Community.
