FME Transformers: 2026.1
Categories
Geometries
Related Transformers
AreaBuilder
GeometryCoercer
GeometryValidator
LineBuilder
LineCombiner
LineExtender
Snapper
Snipper
LineCloser
Jump to Configuration
  • Creating areas from unclosed linear features
The LineCloser receives linear features and connects their end points to their start points, creating closed polygons. An additional vertex is added at the position of the start point.
Z coordinates are supported. Where the first and last points of the input feature have the same x and y coordinates but differing z values, the Connect Z Mode parameter determines how the points are handled.
No checking is performed on the output geometry, and self-intersecting polygons can be created.
Non-linear features are passed through unchanged.
  • The AreaBuilder can also close linear geometry into areas, but moves the end vertex rather than adding an additional vertex to close.
  • Use the GeometryValidator to check for self-intersecting geometry after using the LineCloser.
Creating and Modifying Linear Features
These transformers work with lines in a variety of ways.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the LineCloser on the FME Community.
