FME Transformers: 2026.1
Categories
Geometries
Spatial Analysis
Related Transformers
AreaAmalgamator
AreaCalculator
AreaGapAndOverlapCleaner
AreaOnAreaOverlayer
Dissolver
DonutBridgeBuilder
DonutBuilder
DonutHoleExtractor
HoleCounter
LineCloser
LineOnAreaOverlayer
TopologyBuilder
AreaBuilder
Jump to Configuration
  • Creating polygons from linear features
  • Checking linear network topology
The AreaBuilder receives features with linear geometry (lines, paths, and polygons) and creates areas wherever the linework surrounds closed shapes.
Areas are output, as well as any geometry not used for area creation.
Attributes may be merged or dropped, or accumulated in a list attribute along with an optional direction attribute that records the orientation of the input features.
Output polygon boundaries may be either lines or paths that preserve the input segments. Where areas are contained within other areas, donuts may be created and the donut holes either output or discarded.
Stricter rules may be applied for successful area formation, including checking for continuous curve direction and internal edges (cycles).
Aggregate geometries are either deaggregated or rejected.
Z values are supported.
Preparing input features for the AreaBuilder
Input features must have clean topology or they will not be used and output as Incomplete. The AreaBuilder has snapping capability, but more pre-processing may be required.
Topology issues could be:
  • Features not terminating at intersections
  • Misaligned nodes
  • Overshoots/undershoots
  • Missing nodes at intersections
These transformers may be useful for pre-processing input features.
Use This For
Description
Snapper
Snapping together misaligned nodes with more options than the AreaBuilder’s built-in snapping.
Brings lines, segments, end points or vertex points of features together if they are within a certain distance of each other and (optionally) if they have attributes in common.
Intersector
Splitting intersecting features, adding new nodes where necessary.
Computes intersections between all input features, breaking lines and polygons wherever an intersection occurs/
Chopper
Chopping geometry into two-point lines, without adding any new nodes.
LineExtender
Adding length to undershoots (followed by an Intersector).
Extends line, arc, or path features at both ends by a specified length.
TopologyBuilder
Building full topology on input features, which includes intersecting them.
Computes topology on input point, line, and/or area features, and outputs significant nodes, edges, and faces with attributes describing topological relationships.
  • As input features must be topologically correct for AreaBuilder to create polygons, it can be useful for checking topology.
  • The AreaBuilder has some snapping capability, but the Snapper provides more snapping options.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases Polygonizer PolygonBuilder
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the AreaBuilder on the FME Community.
