FME Transformers: 2025.2
Categories
Filters and Joins
Spatial Analysis
NeighborhoodAggregator
Creates aggregates of features based on their proximity to each other. Each aggregate that is created covers approximately the neighborhood width and height (measured in feature ground units).
This transformer is used to reduce the data volume of "wallpaper" types of features that have no individual attributes. The resulting aggregates can be output to a system using many fewer records than if each feature was output by itself. For systems that support aggregates, or multi-part features, this can result in substantial performance improvements and greatly decrease storage requirements.
Example
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies None
Aliases Clumper NeighbourhoodAggregator
History
The FME Community and Support Center Knowledge Base have a wealth of information, including active forums with 35,000+ members and thousands of articles.
Search for all results about the NeighborhoodAggregator on the FME Community.
