FME Flow: 2025.2 BETA
Back Up Configuration
To back up an FME Flow, perform the following:
- Back up Tomcat folder, if applicable.
- Back up the FME Flow configuration files.
- Back up repository file versions, if applicable.
- Back up the FME Flow configuration .
Back up Tomcat Folder
Uninstalling FME Flow on Linux removes the contents of your Tomcat directory if you installed the default web application server. This folder is located in the FME Flow installation directory under Utilities\tomcat. If you made custom modifications to this Tomcat, these modifications should be backed up before uninstall.
Back Up the FME Flow Configuration Files
Before proceeding with the primary task of backing up your FME Flow configuration, we recommend manually backing up the FME Flow Configuration Files to a location outside of your FME Flow installation directory, in case you need to refer to them later. These files contain configurations for the FME Flow Database and miscellaneous settings for the Transformation and Repository Managers. These configurations are not included in the primary backup procedure. To restore any changes that were made in these files, you must be able to refer to them when the upgrade is complete, so that you can make the corresponding changes in the replacement file.
Back up Repository Versions
If Version Control is enabled on the current FME Flow, and it is not configured with a remote Git repository, previous versions of repository files are not available following an upgrade.
You can view all versions from the Repositories page (History), and download them as desired.
Back up the FME Flow Configuration
The FME Flow Web User Interface makes it easy to back up your FME Flow. For information about what is included in a backup, see What FME Flow Components Are Migrated?.
To perform the backup, use the Web User Interface tool.
