FME Flow: 2025.2 BETA
FME Flow Configuration Files
FME Flow Core
Filename: fmeFlowConfig.txt
Purpose: Configure various FME Flow Core functions.
Filename: fmeCommonConfig.txt
Purpose: Configure FME Flow security.
Filename: fmeFlowWebApplicationConfig.txt
Purpose: Configure the connection between the REST Service and the low-level FME Flow API.
Filename: fmeWebSocketConfig.txt
Purpose: Configure the FME Flow WebSocket Server.
FME Engines
Filename: fmeEngineConfig.txt
Purpose: Configure the FME Engines, including subsections, pre and post commands, and success and failure responses. For details, see Configuration File Layout.
FME Flow Database
Filename: fmeDatabaseConfig.txt
Purpose: Connection configurations to the FME Flow Database.
FME Flow Web Services
Filename: propertiesFile.properties
For example, if you are using the Apache Tomcat web application server that is provided with an Express installation of FME Flow, the properties file for the Data Streaming service is located at:
<FMEFlowDir>/Utilities/tomcat/webapps/fmedatastreaming/WEB-INF/conf/propertiesFile.properties
If your distributed installation of FME Flow uses a separate web application server, the path to the FME Flow service properties files is where your web application server stores .war files.
Purpose: Configure properties for the FME Flow Web Services. Use this file to set the host for the service and other settings.
Process Monitor
Filename: processMonitorConfigCore.txt
Purpose: Start and configure FME Flow Core processes.
Filename: processMonitorConfigEngines.txt
Purpose: Sets the default FME Engines to start.
