FME Transformers: 2025.1 BETA
Categories
Geometries
Related Transformers
Intersector
LineBuilder
LineCloser
LineCombiner
Snapper
Snipper
TopologyBuilder
LineExtender
Extends line, arc, or path features at both ends by a specified length.
Jump to Configuration
  • Preparing geometry for further processing
The LineExtender receives features with line, arc, or path geometry and extends them at both ends by a specified length in ground units.
Extension angle is the same as the orientation of the line segment leading to the extension point (the first or last vertex). Arc geometry extensions are also straight lines, placed tangent to the arc.
Optionally, the angle of a number of segments back from the point of extension can be averaged. If the Segments to Average value is larger than the number of segments available on the feature, the entire feature orientation is averaged. For arc geometry, the segments are produced by default arc stroking which can produce unpredictable angles.
Two-point linear extensions are output individually as Beginning and End.
A Stretched geometry is also produced. If extended from a line segment, the start and end vertices of the input feature are moved to the end position of the extensions. If extended from an arc, the end vertices remain intact.
If the stretched geometry includes an arc or path, it is output as a path.
Output features receive the same attributes as the input feature.
Z coordinates are supported.
Segments to Average
Input
Beginning and End
Stretched
Default (1)
2
Default (1)
18
  • This transformer may be useful in combination with the Snapper and Intersector to perform simple data cleaning.
Creating and Modifying Linear Features
These transformers work with lines in a variety of ways.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases Extender
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the LineExtender on the FME Community.
