FME Transformers: 2025.1 BETA
Categories
Filters and Joins
Spatial Analysis
Related Transformers
AreaOnAreaOverlayer
Bufferer
Clipper
Intersector
LineOnAreaOverlayer
NeighborFinder
PointOnAreaOverlayer
PointOnLineOverlayer
PointOnPointOverlayer
SpatialFilter
SpatialRelator
TopologyBuilder
LineOnLineOverlayer
Overlays lines on lines, intersecting geometry, sharing attributes, and producing intersection points.
Jump to Configuration
  • Splitting lines at intersections
  • Preparing line features for network topology creation
The LineOnLineOverlayer takes in line features and compares them to each other. Where they intersect, the lines are split, each segment retaining its original attributes and receiving attributes from the intersecting line.
Point features are created at the intersections, and may receive attributes from the intersecting lines.
Optionally, a list attribute may be created to receive attributes (for both lines and intersection points), that will store attributes from multiple features. The intersection point features will also include line direction and angle for each intersecting line.
Aggregates can either be deaggregated before processing or rejected.
  • When choosing to output only one segment for each collinear group (equivalent lines or points in the same position), it may be difficult to predict which of the "original" geometries and attributes are preserved. In general, the features that arrive at the transformer FIRST will be the ones that form the separate segments. Use the FeatureHolder or Sorter transformers to change the sequence of features if this is important.
  • This transformer will preserve measures, based on the rules for the order of features described above.
Processing Behavior
Group-Based
Feature Holding
Yes
Dependencies
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the LineOnLineOverlayer on the FME Community.
