FME Transformers: 2025.1 BETA
Categories
Workflows
EnvironmentVariableFetcher
Fetches the specified environment variable and includes it in a new attribute.
Environment variables are convenient especially if certain standard folders and parameters need to be referenced in a workspace, but the actual locations or names can vary from computer to computer.
The available variables will depend on which platform you are using.
Within an FME workspace you could use the value retrieved to:
  • Define the output location of a dataset (in conjunction with Feature Type Fanout, which is described in the FME Workbench help files)
  • Define the location of a file for the AttributeFileWriter or AttributeFileReader
  • Define the location of a workspace to run with the WorkspaceRunner
  • Write the value to some type of metadata output
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases EnvironmentVariableRetriever
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the EnvironmentVariableFetcher on the FME Community.
