FME Transformers: 2025.1 BETA
Categories
Geometries
Spatial Analysis
Related Transformers
DonutBuilder
DonutHoleExtractor
HoleCounter
DonutBridgeBuilder
Adds internal edges to connect donut holes to the outer shell, producing a non-donut polygon.
Jump to Configuration
  • Preparing donut geometries for formats that do not have donut support
The DonutBridgeBuilder receives donut polygons and connects all holes to the exterior shell with one continuous interior line. The result is a single non-donut polygon.
The connections between holes and the outer shell generally consist of duplicate segments in opposing directions (cycles).
There are no parameters to set.
Features with valid geometry of any type are output through the Output port.
Input features with faulty donut topology are unchanged and output through the Invalid port.
  • To revert to a donut polygon, use a Chopper (chopping to two-vertex lines) followed by an AreaBuilder.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the DonutBridgeBuilder on the FME Community.
