FME Transformers: 2025.1
Categories
Web
Web
Related Transformers
AWSIoTConnector
AzureEventHubsConnector
AzureQueueStorageConnector
GoogleCloudPubSubConnector
GoogleIoTConnector
IBMIoTConnector
KafkaConnector
MQTTConnector
SQSConnector
AzureIoTConnector
Connects to the Azure IoT Hub to publish and receive messages.
Jump to Configuration
  • Connect and control IoT devices
  • Manage device data for use on Azure IoT Hub and other services
  • Interoperability with Big Data analytics platforms
The AzureIoTConnector connects to the Azure IoT Hub via the MQTT protocol.
Supports publishing device-to-cloud messages and receiving cloud-to-device messages as a device.
Optional Input Port
This transformer has two modes, depending on whether a connector is attached to the Input port or not:
  • Input-driven: When input features are connected, the transformer runs once for each feature it receives in the Input port.
  • Run Once: When no input features are connected, the transformer runs one time.
When the Input port is in use, the Initiator output port is also enabled.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies
Aliases
History Released FME 2019.0
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the AzureIoTConnector on the FME Community.
