FME Transformers: 2025.1
Categories
Web
Web
Related Transformers
AzureIoTConnector
AzureQueueStorageConnector
GoogleCloudPubSubConnector
GoogleIoTConnector
IBMIoTConnector
KafkaConnector
MQTTConnector
SQSConnector
AWSIoTConnector
Connects to the AWS IoT Core messaging broker to send and receive messages.
Jump to Configuration
  • Remotely monitor operations for predictive quality and maintenance
  • Home automation, home security and monitoring, and home networking
  • Commercial traffic monitoring, public safety, and health monitoring
Optional Input Port
This transformer has two modes, depending on whether a connector is attached to the Input port or not:
  • Input-driven: When input features are connected, the transformer runs once for each feature it receives in the Input port.
  • Run Once: When no input features are connected, the transformer runs one time.
When the Input port is in use, the Initiator output port is also enabled.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies
Aliases
History Released FME 2019.0
FME Community
The FME Community has a wealth of FME knowledge with over 20,000 active members worldwide. Get help with FME, share knowledge, and connect with users globally.
Search for all results about the AWSIoTConnector on the FME Community.
