FME Transformers: 2025.0
GeometryPropertyRenamer
Renames traits and changes the values of geometry labels.
Features with geometries.
Features with selectively renamed traits or selectively changed geometry labels.
Features that were not modified by the transformer.
Geometry XQuery |
Use this parameter to isolate only a portion of the input geometry. If no criteria are specified, the action will apply to the entire geometry at all levels. Selection can be based on structural location, geometry label, type, appearance information, traits, trait storage types, or definition reference. The syntax used is a restricted set of XQuery, where the return clause is fixed. The basic Geometry XQuery dialog allows you to construct simple selection queries by automatically writing the necessary query based on specified test clauses. Clicking the Switch to Advanced button opens the Advanced Editor, which allows you to type a query free-form, for more expressive queries. Note Once you switch to Advanced mode, you will have to clear all parameters before you can return to Basic mode.
A hierarchical geometry is represented as nodes of type geometry, with attributes containing information about traits, type, and label for each geometry. |
Property to Rename |
Traits: Rename traits with selected names Geometry Label: Change the value of geometry labels based on label pairs |
Names |
Traits:
Specify the exact trait name pairs to rename: the old name of the trait and the new name that should be set on those geometries that match the old trait name. You can enter the trait names as a comma-separated list (Window,Door) or use the dialog that displays when you click the browse button. For example, if the old trait name is “Window”, the new trait name is “Door”, and you select Traits under Property to Rename, a trait that had the name "Window" would be renamed "Door". The new "Door" trait will retain the original value. Geometry Label: Specify the exact geometry label pairs to change: the old value of the geometry label and the new value of the geometry label that should be set on those geometries whose labels match the old geometry label. You can enter the geometry labels as a comma-separated list (Window,Door) or use the dialog that displays when you click the browse button. For example, if the old geometry label is “Window”, the new geometry label is “Door”, and you select Geometry Label under Property to Rename, a geometry whose label had a value of "Window" would be updated to have a label value of "Door". |
| Aliases | GeometryLabelRenamer |
Search for all results about the GeometryPropertyRenamer on the FME Community.
