FME Transformers: 2025.0
GeometryPropertyRemover
Removes selected geometry labels or traits.
Features with geometries.
Features with selectively removed traits or geometry labels.
Features that were not modified by the transformer.
Geometry XQuery |
Use this parameter to isolate only a portion of the input geometry. If no criteria are specified, the action will apply to the entire geometry at all levels. Selection can be based on structural location, geometry label, type, appearance information, traits, trait storage types, or definition reference. The syntax used is a restricted set of XQuery, where the return clause is fixed. The basic Geometry XQuery dialog allows you to construct simple selection queries by automatically writing the necessary query based on specified test clauses. Clicking the Switch to Advanced button opens the Advanced Editor, which allows you to type a query free-form, for more expressive queries. Note Once you switch to Advanced mode, you will have to clear all parameters before you can return to Basic mode.
A hierarchical geometry is represented as nodes of type geometry, with attributes containing information about traits, type, and label for each geometry. |
Property to Remove |
Remove All |
If set to Yes, all candidates will be removed. If set to No, the Filter parameter will determine which candidates will be removed. |
Filter (regex) |
If the Remove All parameter is set to No, the filter will be applied to the candidates for removal, and those that match the regular expression will be removed. For example, if Filter is set to ^sketchup_ and traits are being removed, only traits with the prefix sketchup_ will be removed from the selected geometries. |
| Aliases | GeometryTraitRemover GeometryLabelRemover |
Search for all results about the GeometryPropertyRemover on the FME Community.
