FME Transformers: 2025.0
GeometryPropertyExtractor
Extracts selected geometry labels or traits to feature attributes.
Features with geometries.
Features with newly set attributes based on geometry label or traits.
Features that were not queried.
Features with no geometry properties are output through this port along with an additional attribute, fme_rejection_code, indicating the reason for rejection - MISSING_GEOMETRY_PROPERTY.
Property to Extract |
Geometry Part Selection XQuery |
Use this parameter to isolate only a portion of the input geometry. If no criteria are specified, the action will apply to the entire geometry at all levels. Selection can be based on structural location, geometry label, type, appearance information, traits, trait storage types, or definition reference. The syntax used is a restricted set of XQuery, where the return clause is fixed. The basic Geometry XQuery dialog allows you to construct simple selection queries by automatically writing the necessary query based on specified test clauses. Clicking the Switch to Advanced button opens the Advanced Editor, which allows you to type a query free-form, for more expressive queries. Note Once you switch to Advanced mode, you will have to clear all parameters before you can return to Basic mode.
A hierarchical geometry is represented as nodes of type geometry, with attributes containing information about traits, type, and label for each geometry. |
Prefix Extracted Trait with Geometry Label |
Setting this parameter to Yes will prefix the extracted traits with the respective geometry’s label. If traits with the same name exist on multiple geometries, using this option will allow these traits to exist independently. |
Traits to Extract & Extract Traits as List |
The names of traits to extract from the geometry. If the Extract Traits as List checkbox is active, then the traits will be pushed up as a list attribute of the same name (even if just one trait present). If the Extract Traits as List checkbox is not active, then the trait will be set as an attribute, and if the trait is present on multiple parts of the geometry, one of the values will arbitrarily be the value associated with the new attribute. If no traits are specified, all traits on selected geometries will be pushed up as attributes (creating a list if the trait is present on multiple parts of the geometry and not otherwise). |
Geometry Label |
Name the attribute to contain the geometry label. If a hierarchical geometry is present, multiple geometry labels will be extracted onto a list attribute of the same name. The default value for the Geometry Label Attribute is _geometry_label. This parameter is valid when the Property to Extract is set to Geometry Label. |
| Aliases | GeometryTraitExtractor GeometryTraitFetcher GeometryLabelExtractor |
Search for all results about the GeometryPropertyExtractor on the FME Community.
