FME Transformers: 2025.0
DonutBuilder
- Creating donut polygons
The DonutBuilder receives features with area geometry and constructs donut polygons by cutting holes wherever areas are contained in larger areas.
Attributes may be merged or dropped, or accumulated in a list attribute. An optional attribute may be added that indicates whether the output feature is a hole or an outer shell.
Holes may be kept or discarded.
Aggregate input features are deaggregated before processing.
Z coordinates are supported.
Input geometry and spatial relationships
Input areas must be valid and topologically clean, and must have a Contains or Within spatial relationship to successfully produce donuts. Areas that overlap or share boundaries can produce undesirable results.
Input features are not tested for appropriate spatial relationships. The SpatialRelator or SpatialFilter may be useful for filtering features prior to using the DonutBuilder.
Invalid areas will be rejected.
Nested Donuts
Donuts can be nested, such as an island in a lake on an island in a lake. The DonutBuilder will create as many donuts as there are valid donut areas.
When donuts are nested, the Hole Flag attribute will alternate with each level of nesting. The outermost area is an outer shell (Hole Flag = no), the next in is a hole (Hole Flag = yes), the next in is an outer shell, the next a hole, and so on.
When Drop Holes is Yes, areas flagged as holes are discarded, which may be undesirable when they are nested.
In this example, we have two types of features - a city boundary, and a some historic areas within it. We want to cut the historic areas out of the city polygon.
The city boundary is a polygon with no holes.
The historic areas are also polygons, and are fully contained within the city boundary. They do not overlap or touch the outer boundary anywhere.
Both feature types are routed into a DonutBuilder.
In the parameters dialog, Drop Holes is set to Yes.
One feature is output, a donut polygon.
Note that there are fewer inner boundaries than input historic areas - some were adjacent and produced contiguous holes.
The holes were cut out of the outer area, and then discarded.
In this example, we have two feature types - lakes and islands. Note that small lakes appear to be present inside the largest lake.
There are numerous islands in the lake, and some of those also contain lakes.
The features are routed into a DonutBuilder. In the parameter dialog, we add a new attribute that will flag which output areas are holes and which are outer shells.
The results will be nested - donuts within donuts - and so we need to keep the holes.
The outermost output donut is the lake. Note that the _hole_flag value is no.
The largest island is a donut within a donut, and is flagged as a hole.
Conditionally color-coding the areas based on the _hole_flag value clearly shows the nesting.
- The AreaOnAreaOverlayer will also cut holes in areas, creating donuts where they contain another area and modifying the boundary if areas overlap. It does not flag or discard holes, but may be the appropriate choice in some scenarios.
- The GeometryValidator may be useful to identify invalid geometry prior to processing.
Transformer |
Use this to... |
Transformer Description |
Creates polygons from topologically correct linear features. |
Converts a linear feature to an area by connecting the end point to the start point. |
Combines overlapping and/or adjacent areas into larger contiguous areas by removing shared and interior edges. |
Calculate areas. |
Generalize areas. |
Cuts holes in area features where they fully enclose another area, creating donut polygons. |
Separates donut polygons into outer shell and hole polygons. |
Overlays areas on areas, intersecting geometry and sharing attributes. |
Overlays lines and areas, intersecting geometry and sharing attributes. |
Features with area geometry, including donuts. Areas should not overlap or touch.
Donut polygons and holes as specified in parameters. Untouched areas are also output here.
Features with geometry other than valid area geometry are output here.
INVALID_GEOMETRY_VERTICES
INVALID_GEOMETRY_DEGENERATE
Group By |
The default behavior is to use the entire set of input features as the group. This option allows you to select attributes that define which groups to form. Each set of features which have the same value for all of these attributes will be processed as an independent group. |
Complete Groups |
Connect Z Mode |
If applicable, select a method for handling z values. When viewed in 2D (ignoring Z), a path (which may define the border of a polygon) may appear to be closed as shown in the left figure below. This same path, when viewed in 3D, may appear to be open as shown in the right figure below.
Drop Holes |
Select a method for handling areas flagged as holes (not outer shells):
Merge Attributes
Accumulation Mode |
Select a method for accumulating attributes from holes:
Conflict Resolution |
When Accumulation Mode is Merge Hole, select a preference for handling attribute conflicts:
Prefix |
When Accumulation Mode is Prefix Hole, this value will prefix attribute names provided by the hole. |
Generate List
When enabled, adds a list attribute to the output donut, retaining attribute values for each input feature that became a hole, in the order that the holes appear on the donut.
Hole List Name |
Enter a name for the list attribute. Note List attributes are not accessible from the output schema in FME Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used.
Add To Hole List |
Selected Attributes |
Enabled when Add To Hole List is set to Selected Attributes. Specify the attributes you wish to be included. |
Hole Flag |
When Drop Holes is No, name the attribute to contain the hole flag indicator, either yes or no. |
Yes |
Search for all results about the DonutBuilder on the FME Community.
