FME Transformers: 2024.1
VertexRemover
Isolating vertices
Removing portions of vector geometry
The VertexRemover receives features with vector geometry and removes specific vertices (coordinates) from them.
Specified vertices may be either removed or kept. If they are kept, all other vertices are removed.
Vertices are identified by their Coordinate Index position, starting at zero (0), and a Number to Keep/Remove, which is extended from the given index position. For example -
If keeping coordinates, if the Coordinate Index is 0 and the Number to Keep/Remove is 15, the first 15 vertices will remain and the rest will be removed.
If removing coordinates, the first 15 vertices would be removed.
Vertices can also be identified by their position relative to the end of the geometry, where -1 is the last vertex, -2 is second-to-last, and so on. The Number to Keep/Remove will still be extended forwards (towards the end of the feature). For example -
If keeping coordinates, if the Coordinate Index is -22 and the Number to Keep/Remove is 22, the last 22 vertices will remain and the rest will be removed.
If removing coordinates, the last 22 vertices will be removed.
An attribute _num_removed is added to the features, indicating the number of vertices removed.
Multi- or aggregate geometries, 3D geometries, rasters, point clouds, and non-spatial features will be rejected.
Areas with holes (donuts) will not produce useful results.
In this example, we have a set of rapid transit routes, and want to create points at the end of each feature.
The features are routed into a VertexRemover.
In the parameters dialog, Keep or Remove Coordinates is set to Keep. The Coordinate Index is -1 (representing the last vertex), and the Number to Keep/Remove is 1.
The output features’ geometry has been replaced with a single point, at the end of the feature. All other vertices have been removed.
Note that an attribute has been added, containing the number of vertices removed.
Line or area features to have vertices removed.
Features with vertices removed as specified in the parameters, and an added attribute containing the actual number of vertices removed.
Features with invalid geometries will be rejected and output via this port.
Rejected features will receive an explanatory fme_rejection_code attribute.
Keep or Remove Coordinates |
Select how coordinates are identified for removal:
Coordinate Index |
Specify the index position of the first vertex of interest. The index starts at zero (0), indicating the first vertex. Negative integers are used to indicate position relative to the last vertex, where -1 is last, -2 is second-to-last, and so on. The index value may be entered directly or provided via an attribute, expression, user parameter, or conditional value. |
Number to Keep/Remove |
Specify the number of vertices of interest, moving towards the end of the feature from the position specified in Coordinate Index. The value may be entered directly or provided via an attribute, expression, user parameter, or conditional value. |
| Aliases | CoordinateRemover |
Search for all results about the VertexRemover on the FME Community.
